Advertisement
Sponsored by:
Sponsored by:
Dana 44 gear ratio?
Old 07-06-2019, 08:05 AM
Question Dana 44 gear ratio?
I have a 2012 2dr Jeep jk sport, and I cant tell what gear ratio is in the back axle of my jeep. Its the stock dana 44 axle, but for some reason the previous owner must have taken the metal tag off of it with the information i need.
Im looking to swap out the front axle to a 44, but i cant order it until i have the right gear ratio to match the one i have.
any information would be helpful, i think its a 3.73 but im not certain. if nothing else, if there is another way for me to figure out what ratio it is i'd appreciate the insight.
hotbearjuice is offline
Old 07-06-2019, 09:38 AM
3.21 is most likely, 3.73 is the optional ratio.
Some options are:
Send in your VIN and request a build sheet. (won't help if the previous owner regeared...)
Pull the cover and count teeth.
Lift one corner, spin that tire and count driveshaft revolutions.
Measure your tires (measured, not what the mfg or sidewall says), jump on the freeway and note your rpm's at 70 mph, then plug the numbers into the gear chart.
nthinuf is offline
Old 07-07-2019, 05:23 AM
I am not sure that they are putting the tag on the rear covers any more. I looked for one on my 2013 last week when we had it on the lift, and it was not on it. I am 100% sure the cover has not been pulled on mine.
Do a search on a Jeep Build Sheet. The web site should pop up after a little looking. Add your VIN and it will tell how your Jeep was built, to include gears.
Bob
Bob Roach is offline
Old 07-07-2019, 07:07 AM
TheDirtman's Avatar
They don't put tags on the diffs anymore. best way is to jack tires off the ground and spin while counting the revolutions in the driveshaft. It will need to be in neutral.
TheDirtman is offline
Old 07-14-2019, 12:48 PM
Most Autos had 3.21 most manuals have 3.73. That means most not all. Manual at 60mph with stock 32" tires will say 1950rpm with 3.73. Gives you a rough idea. Not sure what the auto OD ratio is so can't say what that might be.
Sixty4x4 is offline
Old 07-14-2019, 01:50 PM
ronjenx's Avatar
Chock the rear wheels.
Jack one front tire off the ground.
Put a chalk mark on the tire and the drive shaft.
Rotate the tire by hand 2 complete revolutions while counting the drive shaft turns.
The number will be your gear ratio.
A little less than 3 turns will be 3.21 gears.
About 3 turns will be 3.73 gears.
A little over 4 turns will be 4.10 gears.
About 4 turns will be 4.56 gears
A little less than 5 turns will be 4.88 gears
ronjenx is offline
bkg (07-15-2019)
Quick Reply: Dana 44 gear ratio?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
