Daystar Hood Vents?
Daystar Hood Vents?
I'm toying with the idea of adding the Daystars to my 2017 JK to reduce under hood temps and flutter. I looked at the few old posts I could find on them and they generally have favorable reviews, but one person on Amazon or somewhere gave them bad reviews because of where they allowed water to drain onto (I think on one side he said it was draining on the TCM). Has anyone on here put them in and not liked them? When you see the factory vented hoods, do they have any form of water drain system, or just let rain in on the motor? thanks..
There are primarily 2 types of people......ones that say don't worry about water getting in....and others that are overly freaked out about it. I'm more of the first and have a PSC hood louver. That said....I'd kinda agree that letting water drain right over TIPM prob not the best thought....even though it should really be fine. I'd prefer to keep water drainage over the main part of the engine/engine cover myself. You should have a little discretion on where you're installing it....but still have to work around the cross supports on the underside of the hood.
Fix the Flutter
This is probably the best 25$ I have spent on my rig so far.
Daystar? - Driven by Design
They just have a wire mesh there....water drains right in, but they are also located a bit closer to the center of the hood than where most put the daystars. The underside support on 10A/hardrock hood is a bit different than the non-vented regular hoods. I've not installed those vents specifically.....so not sure if the cross support will hinder where you can or cannot locate them on the hood.
regular hood -
10A hood -
regular hood -
10A hood -
I can buy that 10A hood as a complete kit (part #82213656AC) from a dealership in NC for $716, but its 250 miles away from me.. Of course my local stealership wants $856 for the same part.. :(
Alas....I just settled for the PSC cheese grater as $130 was more in my budget.
