was this death wobble?
I had a similar issues. Checked and my steering stabilizer was bent and leaking. Most likely from a trail ride hit. I had nangulator's shop check everything over, had a front end alignment done (It needed some adjustment after I went to 35's) and replaced the steering stabilizer with the Teraflex one. Also rechecked torque on the adjustable sway bar. Issues was fixed. May add adjustable lower front arms to help add caster some time soon but for now it's back to normal. Took a few days of driving over bumps to finally unclinch.
that sounds more like bump steer to me, deathwobble the first time it happens you know what it is because it scares the shit out of you, it's most often extreamly violent shaking almost to the point you have to pull over and ditch your underwear in the weeds after using your sock to clean yourself up
well i couldnt reproduce the problem last night infact it road smooth as hell on all bumps so i dont know what the hell is up.
if its bump steer how do i correct it or what is causing it to have only showed up and disappear in two days. im sure it will happen again
