Death Wobble Question: Drag Link lift/non lift
If you are getting true DW, I hope you went through ALL of your component (joints and bolts) and didn't just stop with the DL. A worn out DL should give you some pretty bad bump steer, but by itself should not lead to all out DW. If it is, it seems like you might have another bug in the system. I've had an isolated worn DL joint before, and if everything else is good, you'll get a solid yank/wiggle in teh steering wheel when you hit a pot hole or bump solidly, but that is definitely different from full on DW where it feels like all hell is breaking loose.
My troubleshooting did NOT stop at the drag link issue.
You may also notice in the PLANMAN video - that he also traces it to the Drag Link end (which I just noticed now), he also finds other issues (ball joints).
Based on the confirmation of others (In this Thread) - I feel confident in my diagnosis.
I have a repeatable DW that has felt like it begins at the passenger side - while I didn't take this as my (seat of the pants diagnoses) it seems that given the wear at the drag link joint that this is the problem.
I definitely have DW (not bump steer), and it can increase in modulation (out of control) under certain repeatable (speed / turn / expansion joint) circumstances.
I did a thorough inspection (while wife was moving the steering wheel) , just like the PLANMAN diagnostic videos - (PART 1) (PART 2) demonstrates.
Sounds like you've been through everything pretty good. Those videos are a great resource. I find myself aiming to hit a lot of bumps other cars are avoiding from time to time just to give the front end a quick test and make sure there's not an issue....LOL. I've got a nice test bump within a few miles of my house too.....hopefully the city doesn't fix it anytime soon!
I learned of the videos here - cause the problem has been driving me nuts Ive been AVOIDING driving the jeep because I couldn't determine where the issue was.
Ive got my (not so) favorite turns and expansion joints that I cringe at as I approach them right now!
Drag link is on the way, ill have it on by Saturday and if that doesnt solve the problem ill move onto the next item
man I don't know SQUAT thats why I come here for help.
my plan is to replace one part at a time until the issue is resolved.
This is my gateway toward lifting, but I want this issue resolved 1st, be for moving to further mods.
Update - source found/resolved
Its been a while & since the Jeep isn't a primary driver I wasn't in any hurry...
I methodically replaced each of the items one at a time, had everything realigned each time...
With the help of folks here I went with all Synergy Manufacturing components because using them will mean I can (further) lift the jeep and not have to buy these parts again.
1st I replaced the Drag link with the Synergy High Steer Drag Link, things did firm up but the problem wasn't resolved.
Next I replaced tie rod w/ Synergy's Heavy Duty Tie Rod, things REALLY improved and only in certain conditions could I induce DW (i.e. heavy/straight line breaking & hit a bump).
Only one thing left....the Drag link....which showed no wear using the tests in the video....but hey I'm gonna lift the jeep anyway (today its only got a TerraFlex Budget boost)....I pulled the (upgraded) grade 80 bolt outta the drag link and I could SEE the elongation or oval-ization of the drivers side mount.
I considered welding some hardened washers over the hole but didn't feel that would be long lasting.
I did some googling and discovered Synergy (Is that luck?) has a nice solution that goes over the Mount Point (no welding)...and certainly heavy duty built to last....
I added the Track Bar Brace and had the jeep aligned AGAIN....I mean this thing is some kinda SOLID now...Im AIMING for pot holes and bumps and its just rock solid (Im impressed).
I think if I ever ended up w/ another (new?) JK, I wouldn't even fool around - I'd put the Synergy Track Bar Brace on it as soon as I drove the (new) JK home!!!
Installing the Track Bar Brace is pretty easy, working slowly I did it in about 2 hours, in the garage, with air tools, but it would be easy to do with hand tools too.
The one thing you need to watch for if you do much wheelin and get some articulation up front is that many front springs will contact and rub on that bracket right there it sticks out and where the sector shaft bracket would attache to. I finally removed my sector shaft brace and cut that section (tab) off.
I just put a budget boost on my Jeep and I've been lurking in posts like this to basically build out a suspension upgrade list. Good info guys, the newbs like me appreciate it!
