Death Wobble Question: Drag Link lift/non lift
Current profile:
Problem:
QUESTIONS:
Thanks,
D-
- 2012 Wrangler Sport
- Teraflex 1.5 inch Leveling Kit (all pucks installed)
Problem:
- Death Wobble
QUESTIONS:
- Will the Teraflex 1853920 Extreme Heavy Duty Drag Link work w/ my TeraFlex 1.5 inch leveling kit
- Will the Teraflex Drag Link work when I lift the jeep further? to 2.5 inches ? or 3 inches?
Thanks,
D-
maybe? depending? could you elaborate, please.
is the Teraflex 1853920 flippable?
does it have to be flipped?
under what circumstances should the drag link be flipped?
what benefits / advantages are there when flipping the Drag Link?
The one you've listed does not flip because of the bend and the type of ball joint. It will fit and is adjustable as far as length. Some of the other drag links have an interchangeable tie rod end where the adjustment is made at the end. Look at the synergy drag link as an example. Generally you flip above 3-4 inches because of what is know as bump steer. Some will say 3 some will say 4. Regardless if you do ever flip you have to raise track bar at the same time. The drag link and track bar have to be at same angle and for steering performance in general you want them as parallel to the ground as possible. I have the synergy drag link and the benefit is it can be flipped. I too had DW with a level kit at the time. Drag link was the cause and fix. I replaced it with a synergy. Later I went to a 3" lift and flipped the drag link with a $10 adapter. The TF flipped uses the same adapter but you have to buy a new end for $180 because of the bend. I don't know if the TF TREs can be replaced.
And one of the Jeep. 3" Synergy springs. The guys from Synergy were awesome in educating me about what was causing my bumpsteer and death wobble. Considering adding their long arm kit next.
