Diablosport Tuner vs regear for 2011 JK?
#21
Its way better than stock. As far as around town I dont have to shift to 1st gear on turns anymore and I usually dont have a problem passing anyone . I had a guy in a stick shift honda civic tuner try to race me the other day and he was quite surprised that a lifted jeep beat him by a car length. Around here it seems that alot of people think that since Im lifted they have to get around me at lights cause Im slow ,they all have that surprised look on there face when they find they cant pass me and get stuck slowing down to get behind me. (ya I kinda drive like an ***hole when people try to pass me and cut me off). On the highway 65-75mph even in 6th gear I can still accelerate and if I down shift to 5th I can still pass people.
#22
#23
#24
Well, I decided to take the plunge and go for the gears first. I found out what the "from" meant. It's for older diffs that require an extra overhaul kit. Mine is a 2011 with low mileage, so I won't incur the extra cost. The Jeep goes under the knife Jan 2.
#25
i also have a 2011 JKU , got a set of 4.88s sitting in my shop. waiting to pull the gun on install after getting back from my rotation in alberta. i have a diablosport trinity tuner but i can only adjust tire size. would the procal adjust for gear changes with my diablosport installed?? this is the only reason i would remove my diablosport tuner. power was ok, the best feature was jacking up the throttle booster to 20% over stock and with my 72mm throttle body my bottom end torques my 35s pretty good. but a regear will help my highway power for sure ! around 1400 for gears and install??? awesome! hope they do good work though.
#26
Well today is the big day. 4:88 gears are supposed to be installed today. I dropped off my jeep overnight and the shop will need 2 days to make sure everything is set up correctly. I'm already missing her but I can't wait to get her back.
#27
#28
I had the Procal, switched to Diablosport 2 weeks ago. I called Diablosport regarding the gear ratio change. The technician told me there was no need for it because the computer will calculate the correct transmission shift points based on the size and rotation of the tire. I really don't know if this is an excuse or it can actually be done like that, but I felt I like to be able to put in the gears that I know I installed instead of leaving it to a weird mathematical calculation. the only reason I do not go back to Procal is because the Diablo costed too much to dump it and I can adjust throttle settings on it. I'm thinking about emailing Diablo with the same question and see what response I get.
btw i love my DS Trinity. great little tool with nice neat options. i notice power in the bottom end and around town, but I'm not sure if its worth the extra coin. i could of used the money for my gears instead. i would recommend to anyone looking to change tire size and all that, AEV is your best bet. ( in the 3.8 and 3.6 )
one thing I've noticed while playing around with my Trinity tunes, 91 tune , i lost mpg. i was getting 18-19mpg with my 87 tune, and right now I'm 17-17.5mpg with my 91. the expense/power ratio isn't worth it either. only a slight bump in bottom end around town. it would probably benefit from a hotter spark/ignition source.
