Diff cover question
Old May 1, 2007 | 01:06 PM
  #21
wayoflife's Avatar
JK-Forum Founder
Originally Posted by onsafari
Hmmm never had a problem with gear oil coming out of my breathers before. Either with my TJ or the JK stock or lifted. I will say it is a must to overfill you diff once you lift it and rotate the pinion angle up. That's why the hole is higher than that of a factory cover. Gotta keep them pinion bearings happy ya know!!!!!
I totally agree with you here especially on a lifted TJ. But, on an axle that hasn't been rotated, filling up to the fill hole of a diff cover like SOLID makes will cause your gear oil to spew out of the breather. Trust me, I speak from experience here
Old May 1, 2007 | 01:13 PM
  #22
wayoflife's Avatar
JK-Forum Founder
Here, this image should help people understand what I'm talking about...
If you fill up to the fill hole on an axle that has not been rotated up, you will have gear oil coming out of your breather tube.
Old May 1, 2007 | 01:14 PM
  #23
captsam54's Avatar
What did you get???? Do they come in RED????:toung:
Old May 1, 2007 | 01:19 PM
  #24
onsafari's Avatar
Based on the diff cover you show I would agree with you. I guess all in all it would depend on the actual diff cover. I have Cranes on mine and fill plug isn't that high.
Old May 1, 2007 | 01:23 PM
  #25
2K1TJ's Avatar
Another thing to remember is if you have a Dana 30 front, I'm pretty sure the capacity is less than the D44. Seems like it's about 1/2 quart less, but don't quote me.
Old May 1, 2007 | 01:34 PM
  #26
Northridge4x4's Avatar
Sponsoring Vendor
it really is about how much that axle can take. If you over fill the axle it will create a pressure inside the axle which will then push it out of the vent tube.
If you have to see for yourself fill those puppies up just keep some cat litter with you to clean up the oil slick.
David
Old May 1, 2007 | 01:38 PM
  #27
SCF's Avatar
SCF
The Rock Crusher 44 is designed around the High Pinion 44, according to Grant.
Old May 1, 2007 | 04:33 PM
  #28
gergy9's Avatar
I got the SOLIDS and spray painted red and added some black paint detail on top. THey look sweet! I will try and get some pics tomorrow.
Old May 1, 2007 | 07:17 PM
  #29
jared1843's Avatar
I got a rockcrusher front and SOLID rear. Both are unpainted I believe, so you can choose the color. I have a nifty idea for mine and will post pictures when I get them done.
Old May 2, 2007 | 05:29 AM
  #30
captsam54's Avatar
Cool. I would like to see them..!!
