Do I need Adjustable Rear TB to adjust Pinion Angle ???
I'm installing a Tatton Rear DS on my JK. I bought JKS rear upper control arms to set the angle and JKS spring perches to make sure my springs stay straight.
Am I also going to need an adjustable Rear Track Bar since I assume I won't be able to rotate the axle and keep the track bar mounting flanges aligned with the factory bar ???
Thanks ...
Thanks ...
After installing Woods drivetrains, I corrected rear pinion angle with adjustable UCAs, but I got interference between the top of my diff cover and my factory track bar. Spring shims and a JKS adjustable TB was the remedy.
No binding and no interference.
I'd do the TB too.
I'd do the TB too.
I'd do the TB too.
I'd do the TB too.
