Does any one use AEV bade for stock scissor jack.
My jku is 2.5 lift and 34' tire..
I bought my bottle jack from harbor freight, but even it could not lifted my tire from ground...
So does any one use aev base for stock scissor jack to lifted jk?
Or recommend me some other jack that can be used to more than 2.5' lifted jk..
Floor jack is good.. But i'm living at apt.. So.. I don't have garage...
In case you have trouble finding your other thread, here is a link to it.
https://www.jk-forum.com/forums/modi...r-jack-261099/
The stock jack will work on a Jeep with 34" tires. The axle tube on a Jeep with 34" tires is only one inch taller than a Rubicon model. A square of 2X4 under the jack base will help.
You have 34 foot tires? How do you fit those with only 2.5 inch lift? You must have serious rubbing..
Yes the AEV jack base is great. But you should jack from the axle, so even if you have a lift the stock one should work.
The guy wants to replace a 34 foot tire, but the JACK is his problem ?? ...
