does anyone make a 1 inch rear spacer?
I would think the ideal setup for leveling the jk and running 33s would be a 1 inch rear spacer and a 2 inch front spacer. Anyone make a 1 inch rear spacer?
Would it be possible to cut the FT 2 inch spacer?
That would also work, I want to run 33s but with the 2 inch kits they look small and on a stock setup they work but Id like to have a little more room for articulation. 1 inch in the rear and 1.75 in the front would be perfect in my opinion.
Teraflex makes a 1" spacer which incorporates their spring retainer "cone." I considered using their 2.5" spacers up front and the 1" in the rear to run 33's, but decided to go with the 3" and 35's.
the "More" spacer is actually M.O.R.E. (Mountain Off Road Enterprises) . It is a high quality bidy lift and is available only in a 1" size. ! inch body lift is about the most that you would ever want as far as a body lift goes, but they are widely used and accepted.
ahh a body lift, I really don't want to do one of those. Thanks for the info tho.
