JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Door leak (https://www.jk-forum.com/forums/modified-jk-tech-2/door-leak-302550/)
Bjl May 4, 2014 03:51 PM
Originally Posted by MsFrankie (Post 3903670)
I am having the same problems with both front doors leaking. The dealer tried fixing it and during the process somehow created a leak in my driver side panel which now collects water every time it rains, and the water drains out of the front clamp above and onto the media center. We got rain last night and I went to wipe up remaining water on the driver and passenger side floors. Lifted the carpet and I noticed that there were holes drilled into the floor to drain the water. Can anyone confirm that there are only the plugs on the floors for water drainage, not regular drilled holes. I am livid about this!!! Thanks for any input... <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=550545"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=550546"/>
Yes just pull the plugs to drain, that's what they're for. There's 9 I believe throughout the jeep
OH9JK May 4, 2014 05:08 PM
We got rain last night and I went to wipe up remaining water on the driver and passenger side floors. Lifted the carpet and I noticed that there were holes drilled into the floor to drain the water...looks like a quick fix the dealer had tried to drain the water without me knowing about it. Can anyone confirm that there are only the plugs on the floors for water drainage, not regular drilled holes...I don't recall seeing drilled holes in the floors like this. I am livid about this!!!
Attachment 550545Attachment 550546
Oh wow...someone at the dealer should be pimp slapped! There are drain plugs in the floor but those holes are not factory. :naw:
Michel347 May 5, 2014 06:05 AM
:omg: Wow ! I think that they would get non-factory holes from me ... :cursing:
DunnyBunny May 5, 2014 06:40 AM
Need the file in this
Krynn May 5, 2014 06:51 AM
I had a leak in the same spot, and fixed it by adjusting the angle of the windshield.
I had noticed that the gap between the door and the a-pillar was wider at the top of the door than it was down by the hinge. So I loosened the bolts holding the windshield in place, pulled the windshield closer to the proper position, then tightened the bolts. It's still not perfect, but it no longer leaks. I might eventually redo it so that the gap is perfectly even, but with the leak fixed I'm not in any particular rush.
bmartin4 May 5, 2014 07:04 AM
Can you show me pics of what you did?
FDHog May 5, 2014 01:11 PM
What the hell is that!
I'd be pissed. Didn't the moron see the big rubber drain plug?
Krynn May 7, 2014 06:54 AM
Sure, no problem. It'll be a few days before I can take them though.
© 2026 MH Sub I, LLC dba Internet Brands
