Drag link rubbing
Old Oct 11, 2018 | 02:50 PM
jscribn1's Avatar
Default Drag link rubbing
I'm running 3.5" MC springs and all 8 RK arms. As seen in the pics my synergy drag link is rubbing on the tie rod and steering stabilizer. I want to do the flip kit to high steer but I can't do the TB relocation bracket due to the truss on my D30. If I do the flip without the TB bracket will I cause myself more issues? Other alternative is to cut the bracket off and weld on the synergy TB bracket. Cutting and welding is last resort. Thanks for the help!
Old Oct 11, 2018 | 04:05 PM
resharp001's Avatar
Loved
Community Favorite
Correct, definitely don't do the flip without raising the TB bracket, that will just cause worse issues. The correct thing would be to cut off the TB bracket and weld a corresponding raised TB bracket, but understand the conundrum of not wanting to deal with that.
Old Oct 12, 2018 | 02:49 AM
karls10jk's Avatar
You should be able to loosen the end on your drag link and rotate it up. RuffStuff sells a little piece to keep the joint sitting up straight and then you could rotate the bend to be over and ahead of the tie rod.
Old Oct 12, 2018 | 04:59 AM
TheDirtman's Avatar
Simply put a generic after market mount on the axle truss. Lots of companies make them. Ballistic, WFO, Genright, Ruff stuff, Barnes 4x4, chassis unlimited, blue torch fab are just some of them. You will have to do some custom trimming on the bracket but its not a big deal.
Old Oct 12, 2018 | 06:18 AM
jscribn1's Avatar
Thanks I'll check those out today!
Old Oct 15, 2018 | 06:06 AM
jscribn1's Avatar
I was able to loosen the jam nut, and pinch bolt. This allowed me to rotate the entire link up away from the tie rod. I've got good clearance now. I'll wait until I upgrade to a D44 to flip the steering and track bar. Appreciate the help!
