JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   drive shaft vibe question (https://www.jk-forum.com/forums/modified-jk-tech-2/drive-shaft-vibe-question-37731/)
greggradwohl Apr 24, 2008 05:50 AM
With an unlimited with adjustable CAs and jereel shafts, do you expect drive line vibration to increase as lift increases? Or, to be precise would you expect a 4.5" lift to vibrate more than a 3" lift?
If so, (same setup) is there a lift height that has no perceptible vibration?
wayoflife Apr 24, 2008 06:02 AM
Where you'll feel the vibrations is on the front drive shaft and those can be gotten rid of by reducing your caster. This is somewhat of a pain because at 4.5" of lift, more caster will help keep your Jeep driving straight but vibes aren't a good thing and it's better to get rid of them or at least, as much as possible.
MAROONJEEP Apr 24, 2008 06:09 AM
but is a little vibration going to hurt anything or just be annoying?
greggradwohl Apr 24, 2008 06:11 AM
Forgive me if this is obvious. So, it is easier to avoid vibes with less lift? Meaning it is easier to find a compromise in caster angle to eliminate drive line vibes and maintain handling?
101gargoyles Apr 24, 2008 06:14 AM
As with any type of machinery, vibrations and noises or excessive temperatures need to be eliminated to prevent premature mechanical failures.:yup:
wayoflife Apr 24, 2008 06:24 AM
Nothing to forgive as your question is a good one. And, to answer it, yes, less lift will cause less of an angle on your drive shaft and this will reduce your chances of getting vibes even if you have more caster.
Exactly - mainly you will see failures in things like seals causing leaks and eventually your u-joints.
© 2026 MH Sub I, LLC dba Internet Brands
