Drop pitman issues
Well I have to choose between the AEV high steer or the Tera draglink flip. One is axle side TB bracket the other is frame side. I know there has been alot of debate on here on which is better. It seems this choice is 6 one way and half dozen the other. I'm leaning towards Tera's kit since I have c gussets installed and the AEV would have to be trimmed to fit. I'm just wondering if one is better than the other AEV or Teraflex
TeraFlex's #1600440 Flip Drag Link kit lowers the front roll center axis with that trackbar drop bracket. You have a front and rear roll center axis, both need to be on the same plane or the front lower for better handling. Raising the trackbar off the axle raises the front roll center.
In the rear, it it's always better to have a axle mounted trackbar bracket. A rear adj. tb only recenters the axle, it doesn't help correct the geometry.
It's a Jeep, raising the roll center can be a good thing.
My rear TF axle bracket raised the Trackbar, plus I have their new Monster adj TB in the rear. Now being as that my front and rear are basically at the same angles(opposite of course) and both centered, I'd say my geometry is pretty good. Hell, it rides and handles well anywho. I'm not a geometricision
That's good to hear, this is my first build and all this time I thought the rear tb bracket was just to recenter the axle while using the stock tb. Thanks for the advise. I got rid of my frame bracket in the rear when I installed the jks tb....I guess I'll order an axle bracket along with what ever I end up choosing for my front issues.
