Engine/Oil Skid to work with Currie VXR60 Axles
I recently installed Currie VXR60 axles and the JCR engine/oil skid will not work with it. The differential makes contact with the corner of the skid and mounting arm.
In the pic I circled where it is making contact. Anybody know of a skid that should work with my set up? (VXR60s with RK 3.5 lift)
I looked the Evo and it looks like they would work. However, strictly based upon pictures, I can't say that I am a huge fan of how the tranny skid runs up/over the exhaust cross over and the exhaust/cross member skid then is separate to cover the cross over pipe which creates a "ledge" if you will that can either catch on something or hold mud. Not a solid/flat belly pan. It may no be a big deal, but I'm just not sure on it.
Artec may or may not work. Don't know for sure.
That skid is overkill and, IMO, unnecessary.
I'm assuming you're running 40's with those 60's? The EVO oil pan and trans skids are really all you need unless you're going to be running some gnarly red trails where body damage is inevitable, and/or you don't trust your spotters. If you can't return or sell it, I'd just trim away with an angle grinder until there's no more contact.
Any opinions on what I have pointed out with the Evo skids?
I wonder if the Artec, River Raider, or M.O.R.E. skids would work as they seem to be more narrow than the JCR?
I had the same issue with the Currie 44. I have the rock hard skid. We had to trim it and reshape a bit to make it work. Of course Currie and rockhard have never heard of it.
I hate to mention his name, but Wayalife (specifically Eddie) really showed us how much of a beating the stock skids can take. Bolting a bunch of skids (weight) underneath is mostly unnecessary. Protect what's important. Like I said, just my $0.02.
Then again, who am I kidding....if I had the $$ to burn I'd get the Artec kit.
I wouldn't worry about it. All you need is an oil pan skid, diff covers, and a transmission skid (if it's an auto). Once the stock cross member gets all beat to hell, replace it with a thicker one (Artec, Evo, Clayton). The stock transfer case and gas tank skids do their job very well, and don't need replacing. I have beaten the living hell out of my gas tank skid to the point where my Jeep would take one less gallon gas. I dropped and flattened the skid with a BFH and shot it with a coat of paint. All good for more abuse. The gas tank is completely fine, and the Jeep fills up to full again. I might get a thicker skid plate just for the sake of saving myself that hassle again, but the stock one really does protect well.
Then again, their system works and people don't seem to be having the issues you're worried about. It's a valid concern, but on 37's and 3.5" of lift...that area is pretty tucked up and out of the way anyways. With good lines, I doubt you'll ever have issues with the exhaust crossover.
I exchanged messages with BosRacing on facebook and they said they are running Artec skids with Currie VXR60s with RK 3.5 long arm suspension. I would think it would work with my set up (Currie VXR60s and RK 3.5 mid arm) as well. Shouldn't it?
