Esp kicking in after drag link flip
#21
Originally Posted by DJ1
Throw your old draglink back on and report what happens....
#22
You do not need a Procal to check the steering wheel center.
Is the steering wheel centered or not?
If it is off, just a little bit it will cause the problem you are currently encountering.
#24
When you did the flip kit did you raise the track bar at the same time? If so, did you adjust the trackbar to center the axle under the jeep before you installed the draglink? I'm just wondering if your axle isn't centered and you adjusted the draglink to center the wheel, that would cause you to "crab walk" down the road and could cause you issues even though the wheel is straight. To check if the axle is center I use a tape measure to hook on the top of the coil spring pocket and measure out to a common tread block on each tire.
Edit: In your pictures it kind of looks like your trackbar is not mounted to a high steer bracket. If so, running your draglink flipped and your trackbar in the stock mounts will cause bump steer because they are supposed to be parrallel.
#25
I was noticing the same exact thing. Looks like a stock track back and no adjustment brackets whatsoever to accomodate the lift. I'm guessing he has some pretty severe bumpsteer with the drag link and track bar that far out of whack. Bad bumpsteer could cause the ESP light to come on.
#26
#27
I've used the Synergy flip kit with success on two JKs. Good parts. I'm using an EVO track bar bracket from their truss now with an Ultimate Offroad Dynamics flipped drag link. I refer axle side myself.
#28
#29
You are correct there is no track bar relocation bracket. Now I just need to figure out weather it is worth it to just put the stock drag link back on or try adding the bracket.
#30
I do have a adjustable track bar and the wheels are centered under the jeep. I didn't think I needed to relocate it if the track bar was adjustable. But if I understand ya'll correctly the angle of the track bar is as important as the wheels being centered under the jeep
