ESP Will this fix problem?
Old Jun 17, 2007 | 02:30 PM
AZJEEPFAN's Avatar
Default ESP Will this fix problem?
I know there has been some talk re: ESP and I just installed a 4" lift on my unlimited. My steering wheel is off by about 1/2 turn and my ESP light goes on and off. Im getting an allignment tomorrow- do I need to tell them anything to do anything special so that the ESP switch does not come on anymore?
Old Jun 17, 2007 | 02:58 PM
usmcdoc14's Avatar
you can adjust the drag link enough to turn it off you know.
loosen the 2 9/16 nuts on the drag link coupler and rotate the coupler "up ward" around 4 complete times or until the wheels are strait and so is the steering. and then tighten those 2 nuts.
Old Jun 17, 2007 | 03:39 PM
AZJEEPFAN's Avatar
Once loosened , how do you turn the "buckle'?
Old Jun 17, 2007 | 03:41 PM
AZJEEPFAN's Avatar
Also I was wondering should I it up: taking the weight off the front end?
Old Jun 17, 2007 | 04:03 PM
gundybears's Avatar
You don't have to have the weight off the ground, and I was able to turn mine by hand, but try channel locks if not.
Old Jun 17, 2007 | 04:05 PM
usmcdoc14's Avatar
pair O' vice grips
or a strap wrench if you have one. I used a RoboGrip pliers.
and no, it should be with weight on the wheels. turn the adjuster "up" (that will make the drag link longer) a few times. stop. cycle the wheels back and forth and check again. adjust as needed.
I actualy drive mine out of the driveway, circle, and allow the wheel to self straiten as I pull back in the driveway and see how much more I have to go.
Old Jun 17, 2007 | 04:07 PM
AZJEEPFAN's Avatar
Did you have ESP problems after your lift- or did you drive it at all before adjusting steering wheel?
Old Jun 17, 2007 | 04:15 PM
usmcdoc14's Avatar
put on lift, drove around the block, got ESP/skidmarkthing lights.
pulled in driveway, adjusted drag link, drove around block, lights went away.
Brought to dealer for an alignment anyway.
Old Jun 17, 2007 | 06:17 PM
AZJEEPFAN's Avatar
Thanks for the vote of confidence- I was having a hard time reassuring my self that the alignment was going to work. I was preparing to ask my dealer to dis-able if possible. I should know more tomorrow evening, I am dropping it off at a shop near my workin the a.m. . I hope that fixes it!
