View Poll Results: What set up for my daily driver 2012 jku sport/ weekend wheeler
EVO high clearance long arms and coil springs
3
37.50%
Rock Krawler 3.5 Max travel and coil springs
2
25.00%
Save up for a while and just go all out (coil over long arm)
3
37.50%
Voters: 8. You may not vote on this poll
EVO long arms
So looking on Off Road Evolution's website they have one Bolt On Long Arm kit available, The "Extreme High Clearance Long Arm Upgrade Kit"($2300). If i were to purchase this kit, what else would i need to purchase to make this a complete kit? (other than springs/shocks, bump stops, swaybar links, brake lines) My other guesses would be: Front and Rear Trackbar, and High Steer kit. What am i missing that i haven't mentioned and what components would you suggest to complete this kit?
Also, what is the difference between the Control arms that come in this kit and the control arms that are on Wayalife's Rubicat? (Is one type of arm better suited for street driving than the other?) The arms seen in this picture:
Thanks for all your help in advance (I'm just trying to learn so take it easy on me!)
-Sean
-Sean
Sean,
I hate to burst your bubble, but
The High Clearance Kit can ONLY be used with Coilovers. If you would use coils and shocks you would be extremely limiting your wheel travel. It just will not work. We do have the Double D bolt on Long arm kit. Includes everything you need to lift your JK
It features the same control arms and front control arm brackets as the high clearance kit. So when your ready for coilovers its a simple swap of the rear frame brackets and lower rear control arm brackets.
If you need furture info please let me know or give me a call
Chris
Chris@evomfg.com
Chris
Chris@evomfg.com
Sean,
Chris
Chris@evomfg.com
Chris
Chris@evomfg.com
-Sean
Originally Posted by Brightwhite
I say go bolt on coilovers and just replace your stock control arms with a set from rock Kramer, teraflex, currie, jks, or any other.
