JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   EVO Rear Roll Center Correction Trackbar Bracket (https://www.jk-forum.com/forums/modified-jk-tech-2/evo-rear-roll-center-correction-trackbar-bracket-147266/)
hotdogging Oct 11, 2010 08:21 AM
Does anybody on the forum have this? Was initially looking at the JKS bracket to reinforce the rear trackbar but then I stumbled upon this. Looks beefy as EVO stuff is and this seems to reinforce much better? What does everyone think?
hotdogging Oct 12, 2010 06:00 PM
Bump for any info or updates?
hotdogging Oct 13, 2010 05:56 AM
Bump again before work:thumbsup:
hotdogging Oct 14, 2010 10:03 PM
Bump again :)
Evolution Oct 15, 2010 07:55 AM
The EVO RCC was designed to be a brace for the weak factory trackbar bracket and to correct the rear roll center of the vehicle after lift it.
Raises rear trackbar at axle correcting roll center after lifting the vehicle.
• Correcting Roll Center improves on and off road handling
• Restores axle to its centered location
• Bolt on design
• Integrated light mount for rocklight installations
• Can be used with factory or adjustable trackbar
• Powdercoated Black for corrosion resistance
• All hardware included
Off Road Evolution installs the JKS Trackbar bracket brace all the time and it is a great product to brace the factory rear trackbar, but it does not correct the rear roll center.
Depending on what you are looking to get out of the bracket, either would be a good option for you.
http://www.offroadevolution.com/stor...RCC_medium.jpg
http://www.offroadevolution.com/stor...-01_medium.jpg
http://www.offroadevolution.com/stor...-02_medium.jpg
hotdogging Oct 17, 2010 08:33 PM
Thanks Evo, it's on my quote from you guys. Just waiting on the front track bar brace to come out :thumbsup:
UGOTKERN Oct 18, 2010 05:12 AM
Assuming this wont work with the JKS rear spring perch relocator setup?
© 2026 MH Sub I, LLC dba Internet Brands
