EVO Tire carrier with 35 Trail Grapplers??
#21
I like the AEV bumpers as well. I'm looking at those real hard. I feel like an old lady at a dollar store that can't figure out what she wants more lmao.
#23
There are no creature comforts with this thing. There's nothing to stop it from slamming into the side of your rig if you don't open it correctly or its on an incline. Its a heavy son of a bitch, the pins are tedious to get on and off if you use the tailgate a lot. I'm in no way saying not to get it I'm just saying its a heavy duty tire carrier that's it. Nothing else nothing more.
#24
So how durable is this tire carrier, say if you are traversing off a steep ledge and the rear tire drops but doesn't come in contact with the solid ground, and the majority of the jeep's weight slams on the tire carrier, could this potentially cause damage to the tire carrier or worse damage the carrier mounts/rockskin? Just curious because I once had a tire carrier and everytime I would go off a ledge the jeep would end up smacking the rear bumber and or tire carrier on the way down. Now I've installed a BFH rear bumper and the spare goes in the cargo area, but when I move to 37's i dont think its goin to fit back there so I'm sure I'll be needing a tire carrier.
#25
Sponsoring Vendor
#26
Should've clarified myself...with items in your hand and such, they can be a pain in the ass to get out one handed. The pins do drop right in once you tweak it and get it set up perfect.
#27
Sponsoring Vendor
#28
Can it be reverse mounted?
I really like this carrier as well. Looking at pictures, it seems possible to set it up to open up to the opposite side. Is it possible to set up the hinges on the driver side?
#29
Sponsoring Vendor
#30
There are 4 joints that attach the carrier to the skins. Two of these you will bolt down, the other two will be pinned in place. You can use the bolts on either side and just use the pins on the opposite.
