OR-FAB Tire Carrier Problem...
I have been installing my OR-Fab Tire/Jerry Can Carrier all day...Jesus Christ... Got everthing good to go and ready to mount up my tire and I installed the tire lock...I put the spare on and began to tighten the T-handle down...until I ran into the lock. Look at the pictures below...
http://i600.photobucket.com/albums/t...4/SAM_1063.jpg As you can see below, tire tire is flush. http://i600.photobucket.com/albums/t...4/SAM_1064.jpg Here is the rear. http://i600.photobucket.com/albums/t...4/SAM_1065.jpg Either I am missing some hardware or this is NOT the lock intended to go with the carrier. I have looked at others pictures and the lock does not stick out near as far as mine. What is up? Thanks. |
If you flipped the "lock bar" around would you have more room to tighten the tire bar down :thinking: from the picture it seems as if that bar needs to be turn around because of the dropped recess in it
Can you PM me a contact number and we'll call you.
Yates |
Originally Posted by yhudson
(Post 2171615)
Yates |
From your pictures, it looks like you have everything correct.
What back spacing are your rims? What size tire? Just curious. I am also curious what Yates and the guys at OR-Fab say. Top notch guys, they recently helped me out with some questions I had about my tire carrier install, so I'm sure they'll get you taken care of. |
the issue is with backspacing. You can turn the wheel around if you need to. I put a nut on the T handle
http://i794.photobucket.com/albums/y...utonhandle.jpg |
OK, talked to OR-Fab, the backspacing of the wheel is the issue. I went to Home Depot to get a nut, the did not have any...sooo I had them cut a piece of 1" galvanized pipe...fits perfectly. Actually looks like it came with the kit.
Here is a pic. http://i600.photobucket.com/albums/t...4/SAM_1066.jpg I can even go smaller by maybe an inch. I would just like to say thanks to Dave at Northridge and to Yates and Tony from OR-Fab. I made a post, Dave saw it, Yates makes a post for my number, Tony calls and straightens out the problem...all within minutes. And this is after 8pm on a Friday night. Outstanding. :beer: |
What backspacing do you have? I'm just curious.
OR-Fab guys are awesome! They know how to wheel too! :yup:
good job! I'd suggest cutting that pipe down just a bit. You want to make sure the T handle has plenty of thread in the carrier.
