JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Flashpaq help (https://www.jk-forum.com/forums/modified-jk-tech-2/flashpaq-help-258887/)
Krawlersaur Dec 31, 2012 10:17 AM
Flashpaq help
Got my flashpaq a few weeks ago and I set my tires for 34" since that was the true measured size. However it seems like I'm going slower than most people even going slightly over the speed limit. So do I set it to the actual size? Or set it to 35" since that's what is advertised. Thanks for any help.
-Aaron
ninjajmoney Dec 31, 2012 10:43 AM
If you are wanting to drive faster I suggest you use the pedal on the right. :dontknow2:. But seriously, I have my tire size set to what the true measurement was that way my speedo was as accurate as possible. :thumbsup:. I suggest the tow tune
T&ERun Dec 31, 2012 12:20 PM
Measue from the ground up to the center of the wheel (or centercap). Multilpy by two and input that and you should be dead on. You have to account for the weight of the vehicle making the tire "sag" some.
Ryan0260 Dec 31, 2012 02:07 PM
Also, using a gps can help you to fine tune your adjustments to get a more accurate reading
mkjeep Dec 31, 2012 02:22 PM
This... Even an I phone app adjust accordingly. I had to adjust 1/2in down from true measurement to be on.
Krawlersaur Dec 31, 2012 02:31 PM
Awesome. Thanks for the info guys.
© 2026 MH Sub I, LLC dba Internet Brands
