Fox 2.0 Shock Lengths
I'm researching shocks for my JKUR and am hoping someone here can help me answer a question.
I found the length specifications for the Fox shocks based on the Fox part numbers. I'm hoping someone can relate the Fox part numbers to the shocks offered with the Teraflex and/or BDS valving. I'm thinking I want to get the softer valving offered, but don't know which version to buy. I hate buying shocks based on a description like "Good for 2.5-4 inches of lift." I have my measurements and want to ensure I'm getting the right shocks for my application. Thanks! |
What are the measurements you have?
Originally Posted by firejeep508
(Post 4084805)
I'm researching shocks for my JKUR and am hoping someone here can help me answer a question. I found the length specifications for the Fox shocks based on the Fox part numbers. I'm hoping someone can relate the Fox part numbers to the shocks offered with the Teraflex and/or BDS valving. I'm thinking I want to get the softer valving offered, but don't know which version to buy. I hate buying shocks based on a description like "Good for 2.5-4 inches of lift." I have my measurements and want to ensure I'm getting the right shocks for my application. Thanks!
I was able to get the measurements for the Teraflex versions of the Fox 2.0 Reservoir Shocks. I got what I need, but wanted to post it here for the next time somebody else is looking for this information:
[table="width: 500, class: grid"] [tr] [td]Part Number[/td] [td]Description[/td] [td]Compressed[/td] [td]Extended[/td] [td]Travel[/td] [/tr] [tr] [td]1982820[/td] [td]Front, 2.5-4" Lift[/td] [td]15.50"[/td] [td]26"[/td] [td]10.5"[/td] [/tr] [tr] [td]1982819[/td] [td]Rear, 2.5-4" Lift[/td] [td]16.45"[/td] [td]27.65"[/td] [td]11.2"[/td] [/tr] [tr] [td]1982865[/td] [td]Front, 5-6" Lift[/td] [td]17.5"[/td] [td]29.9"[/td] [td]12.4"[/td] [/tr] [tr] [td]1982864[/td] [td]Rear, 5-6" Lift[/td] [td]17.85"[/td] [td]29.95"[/td] [td]12.1"[/td] [/tr] [/table] Hope this helps someone!! |
Hi Guys
Have a look here: http://www.ridefox.com/dl/truck/fox-...2015-lores.pdf At the end are all the measurements. Regards Paul |
Originally Posted by Paul Wood****
(Post 4085820)
Hi Guys
Have a look here: http://www.ridefox.com/dl/truck/fox-...2015-lores.pdf At the end are all the measurements. Regards Paul I had assumed that the Teraflex versions would actually match one of the Fox versions in dimensions and just be pressured/valved differently, but I was wrong. The Teraflex versions are entirely their own specifications, both in valving and in size. That's why I came back and posted the data on Teraflex shocks, figuring that someone would be looking for the specifications in the future at some point. |
Hi
Sorry, i didn't read your post properly....... missed the bit about Teraflex version. Regards Paul |
(Post 4086039)
Hi
Bumping this thread, what are the thought now of those running this shock?
I run the BDS Valved Fox. They are the shocks Metalcloak uses with their fox lifts. Great shock paired with the MC springs, soft enough valving the combo yields a nice ride on and off road.
Running 37's, PSC Fenders & 2.75" bumpstop up front and 3.125" in the rear i use all but 1/4" of the shock travel on all 4 with no rubbing. Call MC for the expanded and collapsed lengths as they use the same shock for both 2.5" & 3.5" kits. |
