Front Driver side tire wearing faster...
Old Jan 15, 2013 | 05:52 PM
Nkrimmel2012's Avatar
Default Front Driver side tire wearing faster...
My right front tire is wearing a good bit faster than the rest and its kind of spotty on the tread wear... some spots lower than the rest. Any ideas?
Old Jan 15, 2013 | 05:54 PM
Staytru06's Avatar
Alignment?
Old Jan 15, 2013 | 06:02 PM
It had on about two months ago... may e about time for another
Old Jan 15, 2013 | 06:09 PM
afpilot82's Avatar
JK-Forum Ambassador
How often do you rotate?
Old Jan 15, 2013 | 06:40 PM
About 6,000 miles...
Old Jan 16, 2013 | 05:29 AM
Ryan0260's Avatar
Is the tire balanced?
Old Jan 16, 2013 | 05:40 AM
It doesn't pull left or right, I guess I can take it to the shop and see what's going on with it
Old Jan 16, 2013 | 05:46 AM
cis911's Avatar
Check all your tie rod ends. My Jeep was doing the same thing and apparently all my TRE were bad.
Old Jan 16, 2013 | 05:54 AM
snakeyes76's Avatar
front driver's side tire wears faster due to the fact we generally make more right hand turns and therefore the weight is trasnferred onto that said tire. now if it's abnormal wear its as said above. rotate more often and do the 5 tire rotation
Old Jan 16, 2013 | 05:58 AM
familytime's Avatar
JK Forum Regional Rep
x2 try rotate at 3k between oil changes if you change at 6k
