JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   FT trackbar/Rokmen Diff cover hitting? (https://www.jk-forum.com/forums/modified-jk-tech-2/ft-trackbar-rokmen-diff-cover-hitting-51692/)
greggradwohl Aug 18, 2008 09:53 AM
I just added a Rokmen diff cover up front. It sure looks like my FT TB is going to hit it with any amount of flex. Anyone have experience with this? Is there a TB with a more radical bend to handle after market covers?
OME 2.5" lift, no CAs
Patrick @ Full Traction Aug 18, 2008 10:32 AM
Could i get a photo of the front track bar and diff cover?
Northridge4x4 Aug 18, 2008 10:34 AM
Riddler Diff cover?
David
greggradwohl Aug 18, 2008 10:45 AM
1 Attachment(s)
Not a great picture, but I think you can see what I mean.
Attachment 11904
Originally Posted by Northridge4x4 (Post 645347)
Riddler Diff cover?
David
Correct...
greggradwohl Aug 18, 2008 02:21 PM
1 Attachment(s)
Another angle:
Attachment 11906
It appears to me more than a couple inches of flex and the TB/diff cover are going to hit.
I would prefer a "wider bend" track bar if there is one. Otherwise, I guess adjustable CAs could pull the axle in an inch or so.
Any suggestions?
SteelMastiff Aug 18, 2008 02:24 PM
That does look close... No clearance problems with my Currie Bar, for what it's worth!
Northridge4x4 Aug 18, 2008 02:35 PM
Looks close jack up the driver side tire and check it out.
David
greggradwohl Aug 18, 2008 05:29 PM
David
I jacked it up as high as my jack goes with no contact. The driver front coil did not compress much though. It appears to me the TB/diff cover will contact before the bumpstops (FT 2") hit.
greggradwohl Aug 19, 2008 07:50 AM
Might someone have a suggestion on a front TB that has a larger bend than the FT?
To be clear, I am not complaining about the FT TB. I know you cant make everything work with everything else.
© 2026 MH Sub I, LLC dba Internet Brands
