Full Traction Rear Track Bar HELP
Old Jul 12, 2008 | 06:16 AM
JK07's Avatar
Default Full Traction Rear Track Bar HELP
Please have a look at the pic. When I rock my jeep left to right the rear track bar moves a lot left to right
Also can someone please give me the size of the track bar. I want to take the track bar off resize it, fix the joint or replace it whatever then put it back
Old Jul 12, 2008 | 07:07 AM
Bodo's Avatar
Not sure what you mean by resizing it. It should be adjusted to center the axle under the body. Check out this for adjusting the front trackbar. Should work for the rear also. Scroll down to find it.
http://project-jk.com/jeep-jk-write-...-end-alignment
Old Jul 12, 2008 | 09:14 PM
08 Unlimited's Avatar
You are either missing parts or for some reason did not install all the parts. On the adjustable end there should be two of the silver metal spacers, one on each side of the heim joint. You only have one installed which is why that end is moving. Plus you have crushed the bracket which is going to be fun to bend back without breaking it.
The other end is missing the two large black plastic inserts that go in the that end. Plus there is a steel tube that goes in the center of those inserts which the bolt goes through. Dig around in the box everything came in for the missing parts. If you can not find them then call FT for some replacements.
Old Jul 13, 2008 | 04:34 AM
JK07's Avatar
Thanks million Mike
That is exactly the kind of information and advise I was looking? Here no body else have a full traction suspension installed locally yet to my knowedlge.
I have tripple checked thats all i have recieved in the box. Can you please take a close up picture of the same end and give me the name of the parts so i can call FT for help.
Thanks
