Gear install problem
Old Aug 17, 2008 | 07:40 AM
element981's Avatar
Default Gear install problem
I had 5.13 installed in my Jeep and picked it up late Friday afternoon. This morning I go out to the garage and notice my front diff is bleeding. I inspect and it appears to be leaking from 2-3 bolts. How do I fix this? Out some seal on just the bolts or do I have to redo the whole seal?
By the way I love the gears.
Thanks!
Old Aug 17, 2008 | 07:44 AM
blkpearl's Avatar
is it leaking around the bolts at the diff cover? if so it is a easy fix. drain dif and clean cover off and housing and resilicone.....if coming from axle tubes then it is a seal issue and take back to shop for them to check....
Old Aug 17, 2008 | 07:46 AM
element981's Avatar
It appears to be leaking at the bolts on the cover. Where the cover meets the diff appears fine.
Old Aug 17, 2008 | 07:53 AM
blkpearl's Avatar
that easy fix, just drain, clean the mounting surface, of cover and axle, sent you a pm...
Old Aug 17, 2008 | 07:55 AM
element981's Avatar
Ok thanks..
Old Aug 17, 2008 | 07:58 AM
blkpearl's Avatar
https://www.jk-forum.com/forums/show...+cover+install
or you can go this route, and use lubeloc gaskets...
Old Aug 17, 2008 | 04:38 PM
seer1's Avatar
Go with Lube Lockers. They make things so much simpler and work like a charm.
Old Aug 17, 2008 | 07:50 PM
Tebo's Avatar
Do you mind telling us how much it cost to have the gears done? I'm curious because a lot of people are getting their gearing done. I've been given quotes of 14 hours labor. At that preice i should just buy new axels
Old Aug 18, 2008 | 06:08 AM
freshjk's Avatar
14 hours to set gears???? That's a rip off!!!
Old Aug 18, 2008 | 08:30 PM
Tebo's Avatar
Thats what i thought so i tried a few shops and they all quoted 14 hours. Front and rear so we're talking 28 hours of labor to swap my gears.
