Gear Question
Old Dec 15, 2012 | 08:12 PM
Maertz's Avatar
Default Gear Question
I have just purchased a front ring and pinion. They are 5.13 reverse rotation snd thick rick and pinions for a rubi 44 front. These should work in my 2009 2 door rubicon correct? i believe they will, but i need a rear ring and pinion. i have fond a reverse rotation, but do i need a thick ring and pinion? any help is greatly appreciated.
Thanks,
Matt
Old Dec 15, 2012 | 08:21 PM
Smashboogie 4x4's Avatar
Former Vendor
It should work, but you will need to also get a 5.13 for the rear before you install that.
Old Dec 15, 2012 | 08:25 PM
Maertz's Avatar
yes i will be installing them together. i hve the 5.13 front reverse rotation thic ring and pinion. just want to make sure i order the correct rear gears. i am about to order a 5.13 reverse roation it just doesnt say thick.
Old Dec 15, 2012 | 08:49 PM
ronjenx's Avatar
The rear gears aren't reverse rotation, are they?
Old Dec 15, 2012 | 09:00 PM
Maertz's Avatar
no idea lol i gotta figure it out though so i can proceed to checkout....
Old Dec 15, 2012 | 09:31 PM
Maertz's Avatar
looks like you could be right ...but not sure if i need thick or not
Old Dec 15, 2012 | 09:46 PM
TheTerminator's Avatar
Rears cannot be reverse, only fronts can. Front axles are basically rear axles put in the front. Because of that, the ring gear in front runs on the concave side, where in rear it runs on the convex side, which is stronger. So to fix that, they reverse cut the ring gear to make the front run on the convex side. This in turn makes the ring gear stronger. Anyways, just get the R&P that specifically says it is for the rear of JK D44.
