JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Gear Question (https://www.jk-forum.com/forums/modified-jk-tech-2/gear-question-257388/)
Maertz Dec 15, 2012 08:12 PM
Gear Question
I have just purchased a front ring and pinion. They are 5.13 reverse rotation snd thick rick and pinions for a rubi 44 front. These should work in my 2009 2 door rubicon correct? i believe they will, but i need a rear ring and pinion. i have fond a reverse rotation, but do i need a thick ring and pinion? any help is greatly appreciated.
Thanks,
Matt
Smashboogie 4x4 Dec 15, 2012 08:21 PM
It should work, but you will need to also get a 5.13 for the rear before you install that.
Maertz Dec 15, 2012 08:25 PM
yes i will be installing them together. i hve the 5.13 front reverse rotation thic ring and pinion. just want to make sure i order the correct rear gears. i am about to order a 5.13 reverse roation it just doesnt say thick.
ronjenx Dec 15, 2012 08:49 PM
The rear gears aren't reverse rotation, are they?
Maertz Dec 15, 2012 09:00 PM
no idea lol i gotta figure it out though so i can proceed to checkout....
Maertz Dec 15, 2012 09:31 PM
looks like you could be right ...but not sure if i need thick or not
TheTerminator Dec 15, 2012 09:46 PM
Rears cannot be reverse, only fronts can. Front axles are basically rear axles put in the front. Because of that, the ring gear in front runs on the concave side, where in rear it runs on the convex side, which is stronger. So to fix that, they reverse cut the ring gear to make the front run on the convex side. This in turn makes the ring gear stronger. Anyways, just get the R&P that specifically says it is for the rear of JK D44.
© 2026 MH Sub I, LLC dba Internet Brands
