Gear Ratio on 6.0 (L96)
Have saved enough pennies to replace my 3.8 (with 198K miles) with a L96 (6.0) engine. Just wondering what gears folks are running with their converted JK? My current tire size is approximately 34". My Jeep is my daily driver. I currently have 4.88, which work great with the 3.8, but I am pretty sure those gears are a little too low for the L96. Thanks for your assistance and knowledge in advance.
misplacetexan (06-26-2019)
I have the 6.0 and L96!in my 08. Run 5:13's on 37s and is my daily driver. If you do more daily driving than anything else then go 4:56. Perfect gear for both worlds thru 38's. Give either MOTECH or RPM Extreme a call to educate yourself further. Good luck and enjoy your swap
misplacetexan (06-28-2019)
Have received an estimate from MoTech and just have to make logistic planning in dropping off the Jeep in Las Vegas. Have to make sure I have vacation plans for dropping off and picking up Jeep.
My JK is heavy, 6500lbs before loaded with camping gear.
5.38's and 40's, 2100 at 70mph+- and I wouldn't suggest any other gearing.
Robbie will say 4.10's but thats great for a light JK not onebuilt up and loaded for trails.
Just a FYI I'm making little over 400 HP-TQ at the crank.
I would talk to John @Overland Performance first before going to Robbie.
Also EXODUS JEEPS is in Texas.
https://exodusjeeps.com/jeep-ls-engine-swap
https://overlandperformance.com/
misplacetexan (06-29-2019)
My 2dr is @ 5200lbs and I'm on 37's and tons , LS-3-6L80E and run 4.30 gears , John do know his shit for sure . Weight and how your rig is configured makes a big difference in selection of ratios .
What is more important is how you will use your Jeep , the way I use mine will differ from the way you or anyone else uses theirs .
misplacetexan (07-02-2019)
The L96 (6.0) installed starts around $15,999 and goes up depending what other goodies you want to add. I am adding a duel row radiator, Camaro SS fan, 2012 tap shift, re-gearing, and a few other things. So, I will be paying over $22K.
Thank you. It's good to know I wasn't far off. I think between doing the engine/trans swap and axle swap, suspension, wheels/tires. I can see why people have 75k into one of these including purchase price. If you have the "best" of everything I could see an easy 100k if you had it all done.
misplacetexan (07-04-2019)
