JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Gears (https://www.jk-forum.com/forums/modified-jk-tech-2/gears-91385/)
hohokom Jun 24, 2009 07:43 AM
Gears
Just got off the phone with a local shop that does regearing, and they are telling me I need to go to 4:88's to move the 35"s I want to put on my JK. I thought 4:10's would be enough. Any opinions...
myklt8 Jun 24, 2009 08:09 AM
if you are having to re-gear, go with the 4.88 or 5.13 (I think 4.88 is nice)
4.11 will do, if you already have them, but most report better results with the lower gears
TeraFlex Jun 24, 2009 08:28 AM
I'm running 5:13's with 37's. New axles will have 5.38's.
wayoflife Jun 24, 2009 08:28 AM
honestly, i am still running 3.73's with my very tall 35" mt/r's and find that my performance has diminished far less than i would have thought. honestly, i would just install your 35's and drive on them for a while before pulling the trigger on gears. :yup:
Doc_D Jun 24, 2009 10:22 AM
With a 6 speed and 35s I'd do 4.56s or 4.88s. 4.56s will put you back to nearly the same ratio as a stock rubicon (4.10s on 32" tires). 4.88s will be a bit shorter
5.13s and 5.38s are going to be awfully short on a 6 speed with 35s in my opinion. You'll be turning considerably more than 3,000 RPM at 75 MPH. 1st gear will probably be useless on the street.
riverzendz Jun 24, 2009 10:45 AM
The shop you talked to needs your money which is why they told you that you need to re-gear.
I'm running 35's on 3.73's and while it's annoying sometimes there's no need to replace them.
HoodJK Jun 24, 2009 01:20 PM
I ran 35's with 4.10 gears for two years. You definitely don't need to re-gear. I went to 4.88 recently and while it's helpful on hilly roads to not need to downshift as much, I would have certainly been fine with the 4.10's.
bigbluejk Jun 24, 2009 01:30 PM
then again... I ran 35s on 4.10s for a week and thought it sucked a fat one. I have an auto though.
BLACKSTONE Jun 24, 2009 04:38 PM
I personally would not run 35's on 3.73 gears.
I would go with 4.88 or 4.56 for 35" tires.
Piginajeep Jun 24, 2009 04:47 PM
you may not need it, but I love the performance of 5.13 gears and 35's with my 6 speed:yup:
© 2026 MH Sub I, LLC dba Internet Brands
