gears and regears
Originally Posted by Cwyatt11
How about cold air intake? What are the views on that? As far as is it worth it ? Does it save mpgs? So on...
I put a Banks Ram Air in mine then took it for a test drive, I couldn't keep my foot off the gas, love that rushed air sound, and the throttle response is awesome. It gives me an extra 1-2mpgs, depending on how I'm driving...
CAI are an easy, somewhat cheap, and beneficial mod. They are definitely worth their money, regardless of how expensive they are, which isn't much btw. The gains are usually around 8-12 hp and 10-15lbs of torque, but specs vary a lot with every brand. And as far as saving on gas, it all depends on how heavy your foot is.
I also noticed increases in mpg. About 2 overall. I love the overall sound of both mods and would recommend Banks to everyone.
How easy was the instal?
Gears.. Leave it to the professionals
CAI is a very simple 20 min job you can do with just a screwdriver.
Exhaust is also very simple with basic hand tools. Took me about 30 mins to do a catback mbrp offroad kit.
Yeh, it's easy for CAI install. Particularly easy for the Banks Ram Air because it has an air box that bolts directly where the factory air filter goes, no need to put a new mount in or anything. 15 minutes installed.
Exhaust is also easy, I put a Magnaflow cat-back exhaust on mine with only some wrenches and a pry bar. I did however have to cut away one of the factory clamps on the original exhaust with a Dremel cutting wheel, but only cuz the thing was so rusted it wouldn't loosen up. Bout 45 minutes total...
2007 JK 4:88 and 34".If you don't have to change carriers ( not sure where the break is now but used to be at 3:73 and up) then $1000 each axel at a shop with warranty. A must with bigger tires. Same for brakes. Rotating mass to start and stop!!
