Gobi Rack Squeak. suggestions?
Have the gobi Rack for my 4 door. Whenever it's cold the contact point at the rear driver side body squeaks non stop. I tried adjusting the mounting, adding grease, changing rubber mounts. No luck.
Has anyone ran in to this? Any thoughts or suggestions? |
Hm...are the rubber "stoppers" cracked or dried out at all?
Originally Posted by ZMagic97
(Post 3859141)
Can you isolate where exactly it is coming from? |
Loosen, then re-tighten both the front bolts and the rear bolts. Mine squeaks a little at fridgid temps in the morning, but that's it.
Originally Posted by Offroad_Elements
(Post 3859154)
X2 ^ Can you isolate where exactly it is coming from? |
