Going to run 33's. Need lift suggestions.
My Jeep finally needs new shoes...
Here is my intention, I want to run 33"s due to the fact that I have stock 3.21 gears and I think putting 35"s on without re-gearing is pretty much out of the question. Eventually, after the Jeep is paid off in a couple years I will re-gear and run 35's without having to change the suspension up again (from what I choose to do now). So with that said I have 2 lift kits in mind; Rusty's 3.25 or Terraflex 2.5 BB.
I see alot of people running 33"s on the TF 2.5 BB and it looks perfect for that tire size. I haven't seen anyone running a Rustys with 33"s.
My question is, will running 33"s on a Rusty's 3.25" Lift look ridiculous? Or should I just go with the TF kit?
Anyone with the Rusty's lift running 33"s feel free to post pics as well!
Is this the one you're referring to?: http://www.teraflex.biz/products/jk-2-5-lift-kit.html
If this is the case Ill go with the Rusty's because I want to do shocks and stay in the $500 range.
All I see from Terraflex is this spacer kit: http://www.teraflex.biz/products/jk-...get-boost.html
Here is the one with the spring and Shock adapters.
http://www.northridge4x4.com/proddet...rod=TF-1351000
and here is the kit with replacement shocks.
https://www.jk-forum.com/forums/show...e-offroad-pics
And here is an idea of what your will be getting with this lift...
I'm most likely going the same route
I have a 4 inch Superlift (which needs upgrading) and 33s. It is too much lift for 33s but I am getting 35s and have 4.10s. I would drop the extra $ on the TF Coil Kit. Then you won't need a new kit after regear and 35s. Do what works for you, and good luck.
Although u dont need a lift to run 33s, I would get one anyway if u intend to wheel, U will benefit from increased flex and increased belly clearance. If u want to put on a heavy bumper and winch at any point in future, I would go with coil lift so u can add spacers to compensate for sag, plus u will get increased flex with coil lift vs just BB. I ran a 3 inch lift with 32s for a while and it looked fine. I dont like the stuffed look myself and the 3 inch lift I have now looks to low for 34s, and I will be updgrading to 4 inch at some in point in time. I like a lot of wheel well showing, plus I want more belly clearance.
I DO want to lift it. But I plan on running 33"s for about 4 years, or until the Jeep is paid off. At that point I will look into re-gearing and putting 35" shoes on. But until then I want either a 2.5" or 3.25", namely Rustys or Teraflex.
Im just trying to decide which one to go with and im also trying to be cost effective and practical. The most wheeling I do is on rutted trails and logging roads in Central Maine. So im not going for a super-flex rig. Just something with a little extra clearance to deal with those rutts and ditches.
So far what Ive gathered is this:
1. Teraflex 2.5" Budget Boost w/shocks: $525
2. Rusty's 3.25" Lift w shocks & Adjustable Track Bars: $550
3. Teraflex 2.5" Coil Lift w/shocks: $640
WWYD?
WWYD?
Have u looked into the teraflex leveling kit? They have a puck kit and a spring replacement (although the spring replacement is for only four doors right now. They are working on a 2 door). The leveling kit will get u 2 inches front and 1 inch in the rear... The spacers run for ~120 I believe.. Plenty of clearance for 33's though
