got my 37s.. need help with control arms..
Old Oct 23, 2011 | 07:02 PM
superjk10's Avatar
Default got my 37s.. need help with control arms..
hey folks i bought some 37s pitbull rocker on 15s daytona im leaning for the OME lt hd kit wich comes with front lowers arms.. my question is do I need rear arms to move the housing back or front lower should be fine? maybe just a pair un the back..? help! thank you
Old Oct 23, 2011 | 07:50 PM
mstrofpuppets's Avatar
I would guess to do it right I would do both front and rear lowers at least. How much lift do you have?
Old Oct 23, 2011 | 08:10 PM
superjk10's Avatar
OME LT provides a bit more than 3" so im going to chop my factory flares and my 37s should fit. more input on control arms would be helpful
Old Oct 23, 2011 | 08:19 PM
Lancejk's Avatar
I'm running 37s with a 4" that worked out to about a 5-5.5" and have not ran into any issues with no arms so fronts would more that likely IMO be fine.
Old Oct 23, 2011 | 09:49 PM
nthinuf's Avatar
One set of arms 'tilt's the axle, used for caster and pinion angles.
Two sets of arms lets you fine tune the caster/pinion, and also allows you to move the entire axle forward/backward in the wheel well.
Up front, lowers are all you will need. In the rear, you would want uppers to set the pinion angle if/when you replace that driveshaft. At appx 3" with 37's, you will want to trim the pinch seam and rubi rails if you have them, but you should not need to move the rear axle.
Old Oct 24, 2011 | 07:30 AM
highwayman's Avatar
37's on my unltd would cause the rears to contact the TUB at the front of the tire @ full bump (TF 3"). No, not the seam, I have already trimmed it to a nub. I needed rear upper & lowers to position the rear axle back a tad to clear. I guess you could run addl bumpstop & limit travel, but why? Just my 2 cents.
Old Oct 25, 2011 | 07:38 PM
superjk10's Avatar
thanks for the input guys i think im going with front lowers and rear uppers and lower.. and later add front uppers...
I have one more concern tho.. where i live its mostly mud and sand.. i want the joint on my arms to be able to take that without having to switch em every year.... I want the toughest there is! i wonder how the 0 maintenance would be? thank for the inputs
Old Oct 25, 2011 | 10:27 PM
Boosted's Avatar
You will definately need to trim the pinch seams in front of the rear tires if you are running stock or non-adjustable lowers. Rock Krawler arms will move the rear axle back an inch but still require some trimming to clear the 37's.
