have a noob question about lifts
Old May 3, 2013 | 05:23 PM
zero_traction69's Avatar
Default have a noob question about lifts
hey all, just ordered my 3.5 rock krawler max travel lift. my question is what are bump stops, i know they stop bumps, but i mean what is the point in upgrading them, why would i need bigger bump stops wouldnt it limit the amount of travel?
Old May 3, 2013 | 05:29 PM
Twinkydog's Avatar
Bump stops limit the upward travel of the axle to keep yours shocks from bottoming out and your tire out of the fender. They have to be the correct height to do both. Just because your tire can't get to the fender doesn't mean you can't damage a shock.
Old May 3, 2013 | 05:30 PM
Jeepstin12's Avatar
The space between your axle and "frame" or frame mount is greater. The shock will also be longer. It prevents the axle from coming up way too much and blowing out your shocks. Get them. Easy to install, inexpensive and well worth the nominal hassle.
Old May 3, 2013 | 05:32 PM
Jeepstin12's Avatar
You can see the white stop (upper) and the black puck (lower) inside the spring on the front and the white bumper on the top in the rear and the metal square stop on the lower.
ID:	453949   Click image for larger version
Old May 3, 2013 | 06:24 PM
Thanks guys!!!! Looks like I have to add bump stops to my list
