Shimmy at 60 after axle swap Thoughts?????
Had swap done at shop had shimmy when I picked it up and they changed lower control arm location and tightened them up and it went away. After a 12 hr ride home shimmy is back at the same speed and rechecked everything nothing loose and had tire balance checked and they're fine. No idea what it could be. Had tie rod and drag link upgrade done at the same time as the swap Thoughts???
