Help!!!!!!!!!!!
Old Oct 27, 2015 | 05:36 PM
Wrangler22's Avatar
Default Help!!!!!!!!!!!
I need some help ASAP!
I pulled out a f250 tonight and was in 4L and due to the situation and placement I was in I think I stressed something. When I drive in 2wd no problems but if I drive in 4H and try to turn in either direction I hear what sounds like rocks grinding. What is this?
Oh and I can drive 30mph and slap it in 4H no issues at that speed just when turning at low speeds.
I have 2011 non Rubi with 5.13 on 35's
Old Oct 27, 2015 | 05:50 PM
jadmt's Avatar
JK-Forum Ambassador
yea that would be pretty normal if you are on dry surfaces.
Old Oct 27, 2015 | 06:58 PM
fultonromero12's Avatar
Yeah, you aren't supposed to drive in 4h on normal dry roads. It's meant for snowy, ice, muddy, and loose terrain. It is normal to hear those sounds on dry pavement. You might even feel like it's jerking a bit. I hope you are just being overly paranoid about any damage.
Old Oct 28, 2015 | 01:09 AM
YETI-09's Avatar
Lol that's not normal. Have you ever broke a rear axle shaft and drove around on the street in 4h for 3 weeks waiting on a new drive shaft? I have, more than once. And never heard no damn "rocks" while driving.
Old Oct 28, 2015 | 03:17 AM
Whiskey Bravo's Avatar
I have the same issue, came without an identifiable incident. My mechanic told me my U joints needed replacement but that in the meantime it was not dangerous.
Old Oct 28, 2015 | 03:31 AM
Wrangler22's Avatar
Yes understood and i typically don't do this just wanted to make sure of what I was hearing. I hope i am not over thinking this. To me I have been in multiple situation before and never had this issue.
Old Oct 28, 2015 | 03:42 AM
BeachJK's Avatar
Have you taken a look at your U-joints?
Old Oct 28, 2015 | 03:43 AM
Yankee's Avatar
I have turned in 4wd on pavement without hearing a bunch of noise, only feel the drive train bind. You may have damaged the u-joints, hopefully not axle shaft/splines or gears. Start with inspecting the u-joints and that area. If you need to, get with a mechanic.
You have 5:13 and a D30. You were not in 4wd pulling an F250 from the front of your Jeep in reverse I hope?
Old Oct 28, 2015 | 05:13 AM
Wrangler22's Avatar
I have looked at them but they seem ok.
Old Oct 28, 2015 | 05:15 AM
Wrangler22's Avatar
Originally Posted by Yankee
I have turned in 4wd on pavement without hearing a bunch of noise, only feel the drive train bind. You may have damaged the u-joints, hopefully not axle shaft/splines or gears. Start with inspecting the u-joints and that area. If you need to, get with a mechanic. You have 5:13 and a D30. You were not in 4wd pulling an F250 from the front of your Jeep in reverse I hope?
NO!!! Definitely not pulling in reverse! I will bring it into mechanic shop either today or tomorrow. I had someone just listen to it while in 2wd and they said you can hear it but definitely not load like when in 4wd.
