Help!!!!
Old Jun 10, 2008 | 09:10 PM
cyberbrain's Avatar
Default Help!!!!
Ok, I am still searching on this one, but I need your help on this. I just got my lift in today All I need is shocks and tires wheels. Now I have cragar soft 8 15x10 -19mm offset sitting in my garage. They do not fit. I also tried the -38mm offset and still wont fit. I am not a fan of running a spacer, or grinding on the caliper mounting bracket.
So I am looking for a CHEAP 15x10 rim that will mount correctly. Any suggestions are helpful. I am looking to get this lift in by the end of the month.
Old Jun 10, 2008 | 09:30 PM
chefgotti's Avatar
check summit, they are also very close to you. if you go to there website you can filter exactly what you want. hope this helps
