Help with DW
I had the same problem as you after i installed my 2.5 rc lift and everything was torqued to spec including my track bar and this is what i did to fix it
- Check your ball joint by lifting the front end of the jeep of the ground and jerking on the two front tires to see if there is any play in the ball joints
- If that is not the problem than change your toe in to 3/8 toe in or 3/8 toe out and test after each adjustment find a bumpy road and hit every bump you see to make sure the dw is gone, if you don't how to do adjust your toe in than there is right up by wayoflife look it up you want
