Help Identify my Suspension/Lift and other questions
#21
Yes, you'll need to tweak the TB length a touch shorter so the axle is centered again, and will then need to adjust the DL to recenter the steering wheel again.
#22
I have to get outside and more work down before it gets too Hot.
#23
Well, I could not get the trackbar to budge when trying to adjust it. I am a bit limited and power tools. Was trying to do everything with hand tools. Stuff just wasn't budging. Does this picture look like its an adjustable trackbar?
Well, I could not get the Control Arms loosened up either so will have to take it is soon to have them installed as well as adjust that trackbar if it can be adjusted.
But what I can tell from the Drag link flip kit it does ride less flighty and bump steer. Which was the ultimate goal. LOL.
Will it hurt the Jeep if that rear is off center by about 1.25" and the front is off by about 1.5"?
#24
You really need some leverage for a lot of suspension type work and jam nuts. 2' breaker bar and a 24" crescent from HF go a long ways, sometimes more useful than power tools, and not a big investment. That front TB does look like it has a jam nut and threads on it, so yes it's adjustable. With the rear too short, and the front TB too long, both axles are cheating to the passenger side. You'll be ok to drive it round till you can get it corrected.
#25
UPDATE: Well, I finally got the ride quality to a 90% improvement and I say that because it still pulls slightly to the left. The shop that did the alignment tried every combo of switching the wheels in case of radial pull but nothing. I am thinking of getting rid of the Bilstein Steering Damper and go with something that is not gas charged as I have read that can cause the pulling. Good idea? The slight pull but drives me nuts. Otherwise, the bump steering and everything I was experiencing is no longer.
I replaced the Trackbars front and rear with Teraflex Adjustable Trackbars. The tie rod ends were shot so replaced that. I did the JKS Drag link flip kit with a new joint at the pitman arm and new clamp. With these changes, it drives so much better. Both axles are still slightly about an inch to the driver's side but will fix that since they are now both adjustable.
I still have to install the Teraflex Cam Bolt Eliminator Kit along with the Teraflex Alpine Lower Control Arms and get the castor to about 5* right now it's around 4.1* + 4.2*.
#26
I've never liked gas charged units for that application. Maybe the best thing for you to do is pull that SS off completely and take it for a test drive. You are perfectly fine to do so. Many people, including myself, don't even use a SS. That will at least give you a quick indication if it's playing a part in the pulling or not.
#27
#28
I'm not suggesting that running without a SS is perfect for you, but by all means, you're safe to remove yours and take a test drive and see if you can feel a difference.
If you decide to scrap the Bilstein, and you can't find a plain ole factory takeoff (which is a perfectly fine SS), look at the TF VSS9550 for $55.
#29
IMO, it's just kinda there as the last minute piece of the puzzle, icing on the cake so to speak, to keep all the steering harmonics in perfect harmony....absorb little bumps and whatnot. There are a lot of people running around on 35s, 37s, 40s without them. If a jeep is set up correctly, you should be able to drive along and not even notice it's not there. If a gremlin pops up in the steering system, you catch it much quicker too....cuz there's nothing trying to cover it up.
Great, thanks for the info. Will play with that in the next couple of days and see how I like it and see if it solves the pulling.
#30
