Help me o vibration god
Old Dec 30, 2010 | 11:49 AM
dozerjk's Avatar
Default Help me o vibration god
Hey fellow jeepers anybody outthere have a six inch left on a 2010 rubi just lookin for some outlook on some vibrations I can't get rid of peace
Old Dec 30, 2010 | 12:17 PM
KSRubicon's Avatar
New batteries should help the vibration......
Old Dec 30, 2010 | 12:19 PM
KSRubicon's Avatar
Couldn't resist a vibrator joke. Check you track bar first. Make sure its tight, axle centered, all that. Also, I do hope you put in new CV style driveshafts? If not, that may be it. That's too big a lift for stock driveshafts.
Old Dec 30, 2010 | 12:27 PM
dozerjk's Avatar
O ya nice joke haha ya got teraflex joints in the back and a freel on the front 4wparts in coppe texas is working on it right now awsome customer service by the way just got off the phone with manager he called Tom woods this am so new custom for the front hope this works any other ideas
Old Dec 30, 2010 | 01:34 PM
nthinuf's Avatar
Nice punctuation, makes for easy to understand posts...
How about a little more info on your specific setup (all components) and when/where you are getting the vibration. Certain speeds? When turning? After hitting bumps? Front or back? Started with the lift? Lift and tires at the same time? Psi on the tires? Alignment numbers?
With absolutely no information other than 'can't get rid of vibrations', how can anyone possibly help you...
Old Dec 30, 2010 | 05:41 PM
dozerjk's Avatar
Sorry about the misunderstanding not much on punctuation. I have a 2010 2dr rubicon, with a 6 inch procomp long arm suspension 5:13 gears 35 micky t claws, teraflex driveshaft in the back and a je reel in the front I am getting the vibe from the front shaft at between 48-52 mph and then it settles out. New shaft will be in next Friday so well see if the new custom Tom woods fixes the problem well see what happens. (punctuation)
Old Jan 2, 2011 | 07:33 AM
Monty-'s Avatar
i'd be curious to know what they have your caster set to. that's an awful lot of lift for just the 35's. you might need to adjust your front pinion angle up a bit and go from there. seems like the shop would have tried that first instead of just getting you to order a new d/s. unless i'm missing something here?
Old Jan 3, 2011 | 07:41 AM
dozerjk's Avatar
Ya I would have thought that to. Don't have any idea on the angels yet but if this doesn't fix the problem there going to have to do some drastic moving of parts. 6 inch is a lot I know but wanted to make shur I got high enough the first time ya know :whiskey
