Help with P1731 code
Old Nov 7, 2015 | 04:00 PM
Mschneid's Avatar
Default Help with P1731 code
Went wheeling to today and I believe I noticed after a deep puddle that the tranny stayed in "D". Once I got out on the road to go home it went into "limp home mode" and has a P1731 code.
I did just switch from the AEV Procal to the Superchips 3782 Friday. Opinions please. Should I revert back to stock and reload or do I have to got to the dealer or is there something else I can do?
Old Nov 7, 2015 | 05:36 PM
rsmwrangler's Avatar
Do you know if the tune will touch the trans calibration ? if so, try loading the stock trans tune.
There are more details about the code here, hopefully it's something silly like a sensor or the trans not liking something in the tune, if the trans is low on fluid, then that code can be tripped as well.
Shifting problems
Old Nov 7, 2015 | 06:38 PM
Mschneid's Avatar
I don't think it will touch the tranny tunes on 2012 and up. I will check fluid but it only has 23k miles and then try to set it back to stock.
