Help picking?
Old Nov 4, 2011 | 08:10 PM
dmick33's Avatar
Default Help picking?
I just put on a three inch lift and added some 35s. I know I want to regear next but have some questions. A buddy who is a mechanic said I should put a locker in the rear which I planned and run the d30 til it breaks and put in something bigger then locker it. My question is when I do the rear should I put in axles to? Should I just go ahead and put in different spline numbers or will it be ok to run the stock size? The up front should I take that advice or would sleeves and axles, and again different spline, be good enough? Thanks
Old Nov 5, 2011 | 06:51 PM
dmick33's Avatar
bump help please
Old Nov 5, 2011 | 06:56 PM
Grognard's Avatar
I would go 35 spline on locker and shafts
Old Nov 5, 2011 | 07:00 PM
dmick33's Avatar
Are the true trac the full time locker? And is the 35 for the front and rear?
Old Nov 5, 2011 | 07:06 PM
dmick33's Avatar
Are they that much different than stock?
Old Nov 5, 2011 | 07:19 PM
dmick33's Avatar
I have looked at them but if I spend the money am thinking about selectable? But if the LSD gives good traction I wouldn't mine saving a few bucks? Do you have the 30 up front?
Old Nov 5, 2011 | 07:26 PM
dmick33's Avatar
Yeah I tried to go test out the new lift and tires today but the trail was covered in snow and ice a little to much to chance by myself. I am really torn on what to do next I want gears and lockers but different spline shafts would add alot of money at once and don't want to build up a 30 much if I am going to have problems with it.
Old Nov 5, 2011 | 07:27 PM
dmick33's Avatar
Where in pa are you I used to live there and went to Penn State?
Old Nov 5, 2011 | 07:33 PM
dmick33's Avatar
Yeah thats kinda why I am thinking selectable in rear and waiting to buy a 44 for the front but would like to hear from some people and what they have been through. Thanks for the input.
Old Nov 5, 2011 | 07:34 PM
fadeout's Avatar
This with a Detroit, leave the 30 open.
Also ECHO I'm interested in seeing your long term results with that combination.
