Help! with pics :)
Old Apr 3, 2009 | 10:49 PM
  #111
mkjeep's Avatar
Originally Posted by Hellbound13
Yeah the hole looks wallowed. There is about 1MM of space between the bolt and edge of the hole.
Egg shaped?
Old Apr 3, 2009 | 10:51 PM
  #112
Hellbound13's Avatar
Originally Posted by mkjeep
Egg shaped?
Hard to say but there def appears to be wear there and the bolt is not snug to the hole. If you get a chance at some point pop of your axle side trackbar and stick the stock bolt in to see if it is snug.
Send me the trackbar anyway. I am going to replace it along with the bolts and then go from there. Next step after the will be welding washers. If all that is still no good then Im at a loss.
Old Apr 3, 2009 | 10:53 PM
  #113
mkjeep's Avatar
Will do, hopefully it'll help. I'm goin to bed now. Wife has a bellydance festival to go to tomorrow Will ship Monday.
Old Apr 3, 2009 | 10:55 PM
  #114
Nice. Have fun! Thanks again. Let me know what you come up with if you get a chance to unbolt your trackbar and check the stock bolt. Night MK.
Old Apr 4, 2009 | 06:15 AM
  #115
mkjeep's Avatar
I'll check on Sunday and let you know. Also on my list is, change frt brake pads, rotate tires and install my driveshaft that I just got back from je reel( they had to lenghthen re-balance and fix the cv joint) I'm doing a re-torque of all suspension parts anyway.
Old Apr 4, 2009 | 07:08 AM
  #116
Thanks man. Let me know this way I'll know what to check for on Tuesday.
Old Apr 5, 2009 | 09:04 AM
  #117
JKRockStomper's Avatar
Update: Reinstalled the JKS front trackbar with new hardware. The trackbar holes in the frame, axle, and JKS trackbar are not wallowed out. The new bolts due fit tighter in all the above units but the Death Wobble is there.
Old Apr 5, 2009 | 10:00 AM
  #118
Tank's Avatar
so you still didn't get it aliened? that wouldn't work.
Old Apr 5, 2009 | 10:10 AM
  #119
I got it aligned multiple times during this duration. I replace the SS with a beefer one also. The alignment shop just loves me.
Old Apr 5, 2009 | 10:53 AM
  #120
Tank's Avatar
They cant tell you whats wrong with it. i had a shake with mine and my wifes jks after i installed the lifts. got them aliened and went away and they ride better. every jeep i have ever seen with this problem gets fixed with an alignment, and thats alot of jeeps. take it to a quality shop for an alignment and if its not fixed the should be able to tell you whats wrong.
