Help please
Old Mar 30, 2009 | 11:23 PM
geekguy's Avatar
Default Help please
Hi everyone I am new to the forum and I just got a new Unlimited Rubicon. I just installed the Terflex 2.5 bb with shock extentions and 1.5 spider trax wheel spacers. After a couple of days of driving I noticed some oil splatter in the front driver side wheel well. I found it was coming from a hose that leads out of the front axle then runs up next to the shock absorber. Here are some pics:
Thanks in advanced for your help.
Old Mar 30, 2009 | 11:32 PM
wayoflife's Avatar
JK-Forum Founder
hey geekguy, welcome to jk-forum!!
regarding your post, is it safe to assume that you just serviced your differentials or installed new diff covers? what you are looking at is your axle breather hose and it is pumping out gear oil. this is very common when it is overfilled and really no big deal. just kind of stinky and messy.
Old Mar 30, 2009 | 11:34 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
thats the axle breather, some others have reported same problem, the axle was most likely a little overfilled from factory...it will make a mess but will eventually stop and should be fine, you could tell your dealer about it if you want but it really should be ok.
Welcome to the forum and congrats on the Jeep
if you like deep water/muc you may even want to extend your breathers, I did write up on it here is link
https://www.jk-forum.com/forums/jk-write-ups-39/breather-tubes-extended-46802/
Old Mar 30, 2009 | 11:38 PM
geekguy's Avatar
Sorry Im new to this. Maybe this may work.
Old Mar 30, 2009 | 11:40 PM
wayoflife's Avatar
JK-Forum Founder
yup, definitely your breather hose and what you are seeing is gear oil. no biggie.
Old Mar 30, 2009 | 11:47 PM
geekguy's Avatar
No new diff covers or differentials serviced but it is a new vehicle.
Old Mar 30, 2009 | 11:48 PM
geekguy's Avatar
https://www.jk-forum.com/forums/showthread.php?t=46802
Thanks for the info and the write up
Old Mar 30, 2009 | 11:49 PM
wayoflife's Avatar
JK-Forum Founder
yeah, as tkob1060 said, it was most likely overfilled from the factory. no big deal.
Old Apr 1, 2009 | 12:51 PM
IMFletch's Avatar
Mine did the same thing when it was new. It will make a small stinky mess then sort itself out.
Old Apr 1, 2009 | 12:53 PM
greenamphibious's Avatar
Just a little Jeep Shart
