Help with re-gearing
The challenging factor is that low RPM's does not always equate to better milage. For instance, when I am running up highway 160 to work it is a 60 MPH speed limit. If I go in OD (with rubi tires and 3.73's) I am running lower RPM's, but the motor lugs a lot to keep up the speed. I actually get better MPG by disabling the OD and letting the motor run at a higher RPM where it does not lug.
Good luck in whatever you go with, but personally, I feel like I need 4.10's just to keep things optimal right now, and will probably do 5.13's when I move up to 35's or 37's.
Thanks to all for responding. There was much wisdom in your comments. I have the 6 speed and honestly hardly ever off-road (I know... burn me at the stake) but I do want the capability for the few times I do take to the trails.
