Help with violent vibration
I have an 2007 JKU 4door with a 3'' lift. I'm running with 265x70x17. I like what I have, but I'm realizing when traveling on rough free-way or streets that the Jeep gets a very Violent vibration almost ''shaking like'' feeling.
Took it to a local 4x4 shop and they want to replace upper and lower ball joints, the tire rods, and rebuild the steering gear box almost $1500 plus more depending how the steering box looked!?
Then I took the Jeep to local repair shop. The owner of the shop said I do need both upper and lower ball joints(really the lower, shop recommends doing both because all ready be in there) but not for another 20-30,000 miles, ball joints have small (very) movement and recommends bigger tires to compensate for the 3'' lift.
Any recommendations or 2 cents would be help-full.
If needing tires, any site I should be looking at besides Tire Rack?
Thanks! Semper Fi and God bless the USA!
Call Northridge and order a full set of synergy ball joints (itll be a lot cheaper then letting a shop provide the ball joints), then call a couple of OTHER shops for an install quote.
Don't do anything else until after the bj's are installed and you've driven it.
Quick edit: it may be poly performance instead of synergy, I always get them confused... Potato tomato
Thanks man! I'm calling now!
LOL I know it seems odd. He started talking about the lift I had with small tires that it was off balance (symmetry)? Um, yes he did ask to do the tires but told me to go to Tire Rack . Com and just charge for balance.
They'll probably want damn near 400 bucks to install ball joints. Try a track bar. If your lift didn't included a m ew one get a aftermarket adjustable. If it did..loosen and retourqe to spec with loc-tite. Ball joints are probably a good option as well
