Help with Wheel Width
Old May 17, 2009 | 12:04 PM
EHarris's Avatar
JK-Forum Ambassador
Default Help with Wheel Width
I was on the 4 wheel parts.com website looking at ordering my new wheels. I was looking at the Pro Comp Extreme Alloys 7089 black finish. They have two different types. Both are 16” 5x5 with 4.5 backspacing. However the width of the wheel differs from 8” to 10”. I plan on mounting them on BF Goodrich KM2’s 305/70R16 Load Range D. Which wheel width do I want and how do I know they will be able to mount on the tire I plan on purchasing? Anyone else running this set-up that can give me some info on what to expect?
Old May 17, 2009 | 01:52 PM
jtphoto JK's Avatar
16x8 .. 35x12.50 will also fit a 8" rim.
Old May 17, 2009 | 02:31 PM
EHarris's Avatar
JK-Forum Ambassador
Is there any benefit or disadvantage to having either?
Old May 17, 2009 | 03:33 PM
hobie246's Avatar
I spoke with someone there yesterday and was told those wheels are on backorder until August
Old May 17, 2009 | 03:34 PM
AZJeeper's Avatar
Community Favorite
I'm no expert, but I've always believe that a rim on the narrower side of the spec range is better. It should hold better to a lower air pressure and will offer a bit more protection to the wheel as the rubber sidewalls stick out a tad. A narrower rim will also mean a slightly narrower tire width, so there's that to consider.
Old May 17, 2009 | 04:58 PM
pointingredlab's Avatar
Default 12.50 width
I've seen several places where they don't suggest running a 12.50" wide tire on a rim less than 9", but I see many people on here running them on 8" rims, seemingly without any issues. Anybody have a good explanation as to why they manufacturer's don't recommend it?
Old May 17, 2009 | 06:12 PM
EHarris's Avatar
JK-Forum Ambassador
Is it possible that I should go with the 8" if I were running the 285 and the 10" if I am running the 305?
Old May 18, 2009 | 07:52 AM
EHarris's Avatar
JK-Forum Ambassador
Bump to the top....Looking for some more feedback please. I wanted to order my wheels and tires today.
Old May 18, 2009 | 09:00 AM
RevyJKU08's Avatar
Go with the 8" rim as AZJeeper stated. The 8" rim will hold a bead in low pressure situations much better. I run a 8" rim with 12.50 and had no issues and even a few years back I ran a 12.50 tire on 7inch rim on my trucks and had no issues. The tires you are looking at the 285 (11.2 inches wide) or 305 (12 inch wide) IMHO will work better with a 8 inch rim.
Unless you are going to run a wider tire than 12.50 or like the look of a wider rim then go with the 10 inch rim.
Old May 18, 2009 | 09:49 AM
EHarris's Avatar
JK-Forum Ambassador
Thanks again Triple Jeep. I would rather have the performance over looks. I'll get the 8" width but it looks as if I am going to have to piece together a set of 5 from different places. These are all on national backorder.
