Originally Posted by Dekooy
(Post 4340406)
Thanks for the reply, really appreciate it. That'll save me a few coins knowing that!
Just for reference for anyone else reading, the aluminum structural dust cover between the engine oil pan area and the g238 is part number 53021584AA (or so my research and first hand testimony from others who have done the swap say). The thin metal dust sheild that covers the open bottom of the tranny once mounted is 52107753AC. Yes those are the correct numbers. Here they are all happy and in place: https://cimg8.ibsrv.net/gimg/www.jk-...53c1003800.jpg https://cimg3.ibsrv.net/gimg/www.jk-...ed45bae9b5.jpg https://cimg6.ibsrv.net/gimg/www.jk-...31606b3acb.jpg There are seven SAE bolts for the bellhousing - the four upper bolts are one size, and the two side bolts (with cone or Belleville washers don't forget those) that thread through the block just underneath the dowels and into the bellhousing. The other bolt is a 1/4-20 x 1/2" black oxide for the dust shield. The rest are metric. All the correct bolt part numbers, sizes and lengths are in my spreadsheet on the other forum (I'm Rockystock over there). Recommend using the OEM bolts (and ARP for the side bolts) because the strengths vary and you don't want a grade 5 bolt (or class 8.8 for metric) trying to do the work of a grade 8 (or metric class 10.9). Good luck! |
Oh hey Rockystock! It's great that you're over here too! Between the two of you guys, I'm sure I'll have enough guidance to figure this thing out! It's nice to see the manual swaps getting a bit more coverage now too....i've been dreaming of this swap for years before I started gathering and can remember dismal search results, only a few years ago!
(Post 4340441)
